CAn anyone tell me how to replace the front control panel?
I have one on order. The touchpad cover cracked in a few places.
This may not be the same unit as you have but it will probably be the same basics I copied from another site.
Here is your parts breakdown
Replacement parts for MAYTAG MDB7600AWS | AppliancePartsPros.com
Here is an operators manual. It is for an AWW but yours should be close
http://shared.whirlpoolcorp.com/asse…6_919201_A.PDF
Here is a service manual. tech sheet and a diagnostics flow chart
http://www.servicematters.com/maytag…s/16021814.pdf
http://www.servicematters.com/maytag…s/16023212.pdf
http://www.servicematters.com/maytag…TDD-0008-S.pdf
…for taking the time to reply.
As it turns out, I got the part and with the help of my wife, got it installed.
But have saved all the info you posted for the next time..
Hi, have the links for the instructions changed since posted, I cannot find them. I too need to replace the control panel and would like to know how to do instead of by trial and error ![]()
I find these links do not lead to live pages…are there new links?
