Replacement Part
I must say that I am not pleased with the part. The indented white metal shaft which has been dimpled to allow easy sizing is not very robust. I measured the size of the orignal shaft and matched the length only to find that when adding the plastic adaptor it stuck out from the stove an additonal 3/4". I grabbed the shaft with a needle nose pliers to secure the shaft and I used an electricans pliers to snap off another small piece. The shaft broke completely from the switch. I would expect that the portion afixed to the switch would be a little more robust.
Do you have any solutions to the complete shaft being gone?
Frank
[quote=Frank Howd;124155]I must say that I am not pleased with the part. The indented white metal shaft which has been dimpled to allow easy sizing is not very robust. I measured the size of the orignal shaft and matched the length only to find that when adding the plastic adaptor it stuck out from the stove an additonal 3/4". I grabbed the shaft with a needle nose pliers to secure the shaft and I used an electricans pliers to snap off another small piece. The shaft broke completely from the switch. I would expect that the portion afixed to the switch would be a little more robust.
Frank[/quote]
May I have your email address please.
My address is fh3143@att.com
Thank You
