I purchased a new fascia panel for my bosch dishwasher but there were no instructions as to how to replace it. Do I need to remove all the door screws and do I need a special tool to do it with? Model # SHY56A05UC/14. All I need is a diagram and the tool. Domer
SOLVED-
BOSCH- R/R Fascia to Access Power button ON TOP OF DOOR
Model Number: SHY56A05UC/14 Brand: Bosch
Read Gene’s description here: bosch dishwasher . His instructions apply to this model as well and are EXCELLENT. Thank you Gene!
Note: The first six T-20 screws in his instructions are the LOWER three on each side inside the door which face the rear of the unit. The second six T-20 screws will be the six which remain on the top half of the door.
Page 26 of this by Chriscw:
http://www.cteq.ca/Doc_texte/DishwasherTraining bosch.pdf
will give pictures.
Thanks to Chriscw and Gene
