Replacement of Dishwasher door gasket
We recently noticed water leaking from the corners of the door during the wash cyclic. It is most likely the door gasket. The question is how difficult is it to replace and do you need to replace the splash guard on the bottom of the door?
The door gasket is not too difficult to replace. Regarding the splash guard - you have to replace it only if it’s damaged.
  • The part number for the door gasket is AP2919527
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KUDS23HB0 | AppliancePartsPros.com
