Replacement of control panel
Brand: Frigidaire
**Model Number:**FPID2498SF8A
Main Symptom: replacement of control panel
After replacing the control panel and powering the dishwasher up the control panel goes through a test cycle and then his dead
I ordered the new Control panel from your company
When you start the dishwasher, does it fill with water? You also said you replaced the control panel and are replacing it again. Is it doing the same thing as it was before replacing it the first time?
