I’ve just purchased a house which included an old Westinghouse stove from sometime in the 60s or more likely the 70s. Everything works fine with it except for two of the oven heating elements which do not heat. The broiler element heats just fine, leading me to believe the controls and such are working fine and it is the elements themselves which are faulty.
I would like to keep this stove as it matches the rest of the kitchen. Are there any generic parts I can use to replace the elements?
Going by your model #, it takes a 5300207513 bake element. No longer available on most appliance part websites but some on ********. Also crosses to generic parts- CH2864 or RP716 elements. Not sure what you mean by 2 bake elements? should be one for broiler & one for bake. Go by picture of element to make sure its the right one
I’ve already removed the bottom burner and ordered a replacement, but as you can see there are two elements high in the stove. The very top one works, but the middle one does not. I’ve been unable to find anything that matches the way it mounts.
