Replacement control board doesn't work properly
I replaced a burnt out light bulb with the microwave (GE JVM1650) plugged in and as a result lost function of the bottom range lights. I ordered a replacement smart board RAOTR7T-01 (WB27X10382)and installed it. Now the bottom lights work but the microwave interior vent and lights come on when the door is closed and the microwave won’t heat…please help. I don’t want to be stuck with a 100 dollar useless part and a microwave that doesn’t function.
Check the upper door switch, you may have bumped it during the repair. Remove the control panel and look at the switch bracket. There are 3 switches, top middle bottom. Make sure the door latch is pushing the button on the switch.
Ive got the same problem and cant get A schematic from Ge Im not sure of the position of the switches on the door N/O or N/C?
