Replacement bushing for GTW750CSL1WS tub
Older models can replace tub bushing or drum mounting hub. can’t find correct replacement part for this model.
The tub on this sits down on the shaft and then is held in with a hub nut.
https://www.appliancepartspros.com/ge-nut-hub-wh02x10363-ap5793681.html
