Brand: GE Model Number: GTW680BSJ5WS Main Symptom: After easy installation the new board flashes and there’s no way set the personality code. What happens & when: immediately after plugging in the board flashes. Pressing and holding ANY button does nothing. Once you press Start the unit goes black and becomes unresponsive. There’s no way to set the personality code so this unit is completely useless. Any assistance would be greatly appreciated as many people on the internet, including this forum are experiencing this same issue.
Error Code (if any): n/a
Parts or tests already tried: WH22X35757
It does not do this. I’ve tried many times. I even got the PDF from GE that has the same instructions and nothing happens. As soon as you press (or press and hold) the start button the unit goes black (no more lights, nothing on the display) and it’s unresponsive. Even turning the knob to enter that servicing mode. I can unplug and plug it back in, all the lights slowly flash and then rinse repeat. Nothing seems to allow me to set the personality so I can use washer.
