Replaced water pump since cleaning it didn’t work. Now, the washer appears to be “stuck” in the middle of a wash cycle. Symptoms:
- All keys respond except “Start / Pause” which results in a double beep
- Not able to put the washer into “test” mode
- Water level switch has been tested and found to work properly
- Any water in the tub will drain when washer is plugged in
- No error codes when unit goes into “wake up” cycle
I’m at a loss why I can’t get the Start / Pause to respond appropriately, and even more that the washer won’t reset after being disconnected from power. I have the service guide, but without an error code or being able to access test mode, it doesn’t do me much good.
Thanks in advance…
