Brand:Frigidaire
Model Number:FHGB2735NF2
Main Symptom:Water not dispensing after filter replacement
What happens & when:Mild hiss but no H2) when paddle pushed
Error Code (if any):None
Parts or tests already tried:Took out new “Amazon” filter (after much difficulty).
Released by removing filter shield and pushing up gently on a spring unit between the nozzles.
Put old filter back in. Still no water.
First replacement was the last of a order of three others that worked fine. Bought new OEM filter installed it yesterday 1/8. Had compression but still - no water.
Ideas? Replace the water filter base part or check for something else?
