Replaced thrust bearing kit but still won’t spin
Brand:Maytag
**Model Number:**MAV6200AWW
Main Symptom:pumps but won’t spin
Parts or tests already tried:replaced thrust bearing kit
Replaced thrust bearing kit and got a noise while removing e-clip. Still won’t spin
Does the washer agitate properly? Also, if you rotate the drive pulley in the direction for the thrust bearing to engage, does the brake provide resistance or does it feel like there is not much resistance at all?
