My washing machine won’t stop filling with water. I did the diagnosis by unplugging it while it was filling with water and the water stopped. I bought a new pressure switch/water level switch, model WH12X10065, and installed it by following video instructions. The problem still persists…
Sincerely,
Haven’t done laundry in over a week
Also- I blew air into the hose that connects to the switch…
Open the front panel of the washer and with tub empty, disconnect the pressure hose from the tub air dome on lower left side of tub. Clean out the gunk in the hose and use a wire to get into the air dome to clean it and also flush it with hot water. Be very careful as you don’t want to break the hose nipple off the air dome. Reconnect hose and try again. If that doesn’t fix it, check the hose for holes/splits/cracks, replace as necessary.
http://www.appliancepartspros.com/ge-pressure-switch-hose-wh41x365-ap2046584.html
Eric
