Brand: ge
Model Number: GSS25JFPA WW
Main Symptom: evap fan not working
What happens & when: fan not spinning after new replacement
Replaced board, replaced evaporator fan with included thermistor. Freezer coils get cold, light works, water dispenses but evap fan doesn’t run.
Trouble shooting protocol says last effort would be incorrect wiring, but it’s plug and play so how incorrect could it be? All grounds have continuity, as does the thermostat sensor. Saw voltage at evaporator fan harness but didn’t verify how much.
Any help would be appreciated, thank you.
GE side by side model GSS25JFPA WW
Replacement evaporator fan WR60X10074
