Replaced bake element. Still no oven
Bake element burned in two. Replaced. No broil or bake. SUrface elemts work fine. Continuity test on bake element is 21.5 ohms. Broil element is 35.5 ohms, I have a picture of the schematic and have taken numerous continuity measurements. The selector switch seems to be working fine.
Alll wires/connectors are in good shape.
Need help determining if it might be the thermostat or clock/timer.
I’m not sure how to evaluate the continuity tests fromes these.
Thank you in advance
Scott
Here is the schematic
