how complicated is it to replace the filter housing and water lines? Can you provide instructions?
Elizabeth,
Replacing the filter housing is relatively easy,
Turn the water off to the the refrigerator fill valve.
Turn power off to the refrigerator.
Remove the filter from the housing.
Remove the kick plate grille from the bottom front of unit.
Remove the 2 screws attaching the filter housing to the frame and slide the housing out towards you, then disconnect the tubes, reverse the procedure to install.
The tubing repalcement is a bit more difficult, only because you have to move the refrigerator out to access and replace the tubing from the fill valve to the filter.
Elizabeth,
how do you disconnect the tubes from the housing?
BMW,
You press down on the plastic ring that encompasses the plastic tube,and pull out on the tube where it enters the housing, basically, it’s a compression fit.
Make sure you insert the tube as far as possible, while pressing down on the ring. release the ring and give a slight tug on the tube, to make sure the ring seats tight and seals.
In your case, you could cut the tubes off at the fittings since you’re replacing the housing.
Good Luck,
[LEFT][COLOR=#000000]BMW,
Good Luck,
Read more: http://forum.appliancepartspros.com/refrigerator-freezer-repair/188918-replace-water-filter-housing-whirlpool-refrigerator.html#ixzz1Lc2lT78H
http://forum.appliancepartspros.com [/COLOR][/LEFT]
[COLOR=#000000]should I buy new lines? The old ones seem ok. Is it that simple to replace the lines?[/COLOR]
[LEFT][COLOR=#000000]BMW,[/COLOR][/LEFT]
[LEFT][COLOR=#000000]You press down on the plastic ring that encompasses the plastic tube,and pull out on the tube where it enters the housing, basically, it’s a compression fit.[/COLOR]
[COLOR=#000000]Make sure you insert the tube as far as possible, while pressing down on the ring. release the ring and give a slight tug on the tube, to make sure the ring seats tight and seals.[/COLOR][/LEFT]
[LEFT][COLOR=#000000]In your case, you could cut the tubes off at the fittings since you’re replacing the housing.[/COLOR][/LEFT]
[LEFT][COLOR=#000000]Good Luck,[/COLOR]
[COLOR=#000000]
:)[/COLOR][/LEFT]
[LEFT][COLOR=#000000]__________________[/COLOR][/LEFT]
[LEFT][COLOR=#000000]Read more: http://forum.appliancepartspros.com/refrigerator-freezer-repair/188918-replace-water-filter-housing-whirlpool-refrigerator.html#ixzz1Lc2lT78H [/COLOR][/LEFT]
[LEFT][COLOR=#000000]http://forum.appliancepartspros.com [/COLOR][/LEFT]
[/quote]
[quote=CARLOSSWIM18;426905][COLOR=#000000]should I buy new lines? The old ones seem ok. Is it that simple to replace the lines?[/COLOR]
[COLOR=#000000]
:)[/COLOR][/LEFT]
[/quote][/quote]
Carlos,
That’s going to be your decision, But as long as the tubing is not cracked, brittle or kinked, you don’t need to replace the tubes. Just make sure the insertion end of the tubes are straight and clean, and follow the instructions above and you’ll do fine.
I receive the housing, but before installing I tried to get the filter in place, Yet once I inserted the filter all the way in the housing, this will not turn at all. I requested a replacemente for the part which was sent proptly. But once again the filter would go all the way in but i am unable to turn it to make it fit tight. Is there anything I should do? The filter is exactly the same as the one I had before. Am I doing anything wrong? Thanks for your help.
Carol,
Here are the instuctions for installing and flushing the water filter and system, it’s probably something minor you’re missing.
[B][FONT=HelveticaNeue-Bold][SIZE=1][FONT=HelveticaNeue-Bold][SIZE=1][LEFT]Style 1: Behind the base grille filter
- [/B][/SIZE][/FONT][/SIZE][/FONT][FONT=HelveticaNeue-Roman][SIZE=1][FONT=HelveticaNeue-Roman][SIZE=1]Remove the base grille (see [/SIZE][/FONT][/SIZE][/FONT][FONT=HelveticaNeue-Roman][SIZE=1][FONT=HelveticaNeue-Roman][SIZE=1]“[/SIZE][/FONT][/SIZE][/FONT][FONT=HelveticaNeue-Roman][SIZE=1][FONT=HelveticaNeue-Roman][SIZE=1]To remove the base grille[/SIZE][/FONT][/SIZE][/FONT][FONT=HelveticaNeue-Roman][SIZE=1][FONT=HelveticaNeue-Roman][SIZE=1]”[/LEFT]
[/SIZE][/FONT][/SIZE][/FONT][FONT=HelveticaNeue-Roman][SIZE=1][FONT=HelveticaNeue-Roman][SIZE=1][LEFT]section). Rotate the cartridge counterclockwise to a vertical position and pull the filter cartridge out.[/LEFT]
[/SIZE][/FONT][/SIZE][/FONT][FONT=HelveticaNeue-Bold][SIZE=1][FONT=HelveticaNeue-Bold][SIZE=1][LEFT]NOTE: [/SIZE][/FONT][/SIZE][/FONT][FONT=HelveticaNeue-Roman][SIZE=1][FONT=HelveticaNeue-Roman][SIZE=1]There will be water in the cartridge. Some spilling may[/LEFT]
occur
[FONT=HelveticaNeue-Bold][SIZE=1][FONT=HelveticaNeue-Bold][SIZE=1][LEFT]2. [/SIZE][/FONT][/SIZE][/FONT][FONT=HelveticaNeue-Roman][SIZE=1][FONT=HelveticaNeue-Roman][SIZE=1]Take the new cartridge out of its packaging and remove protective cover from o-rings.[/LEFT]
[/SIZE][/FONT][/SIZE][/FONT][FONT=HelveticaNeue-Bold][SIZE=1][FONT=HelveticaNeue-Bold][SIZE=1][LEFT]3. [/SIZE][/FONT][/SIZE][/FONT][FONT=HelveticaNeue-Roman][SIZE=1][FONT=HelveticaNeue-Roman][SIZE=1]Push the new filter cartridge into the base until it stops.
Rotate the cartridge clockwise to a horizontal position. Flush
the water system (see [/SIZE][/FONT][/SIZE][/FONT][FONT=HelveticaNeue-Roman][SIZE=1][FONT=HelveticaNeue-Roman][SIZE=1]“[/SIZE][/FONT][/SIZE][/FONT][FONT=HelveticaNeue-Roman][SIZE=1][FONT=HelveticaNeue-Roman][SIZE=1]Flushing the Water System After[/LEFT]
Replacing Filter[/SIZE][/FONT][/SIZE][/FONT][FONT=HelveticaNeue-Roman][SIZE=1][FONT=HelveticaNeue-Roman][SIZE=1]” [/SIZE][/FONT][/SIZE][/FONT][FONT=HelveticaNeue-Roman][SIZE=1][FONT=HelveticaNeue-Roman][SIZE=1]later in this section).[/SIZE][/FONT][/SIZE][/FONT]
[FONT=HelveticaNeue-Roman][SIZE=1][FONT=HelveticaNeue-Roman][SIZE=1][B][FONT=HelveticaNeue-Bold][SIZE=1][FONT=HelveticaNeue-Bold][SIZE=1][LEFT]Style 2: Through the base grille filter - [/B][/SIZE][/FONT][/SIZE][/FONT][FONT=HelveticaNeue-Roman][SIZE=1][FONT=HelveticaNeue-Roman][SIZE=1]Locate the water filter cartridge cap in the front base grille. Rotate the cap counterclockwise to a vertical position and pull the cap and filter cartridge out through the base grille.[/LEFT]
occur.[/LEFT]
[/SIZE][/FONT][/SIZE][/FONT][FONT=HelveticaNeue-Bold][SIZE=1][FONT=HelveticaNeue-Bold][SIZE=1][LEFT]2. [/SIZE][/FONT][/SIZE][/FONT][FONT=HelveticaNeue-Roman][SIZE=1][FONT=HelveticaNeue-Roman][SIZE=1]Remove the cartridge cap by sliding it off the end of the old
cartridge. The cap will slide to the left or right. DO NOT[/LEFT]
DISCARD THE CAP.
[FONT=HelveticaNeue-Bold][SIZE=1][FONT=HelveticaNeue-Bold][SIZE=1][LEFT]3. [/SIZE][/FONT][/SIZE][/FONT][FONT=HelveticaNeue-Roman][SIZE=1][FONT=HelveticaNeue-Roman][SIZE=1]Take the new cartridge out of its packaging and remove
[/SIZE][/FONT][/SIZE][/FONT][FONT=HelveticaNeue-Bold][SIZE=1][FONT=HelveticaNeue-Bold][SIZE=1][LEFT]4. [/SIZE][/FONT][/SIZE][/FONT][FONT=HelveticaNeue-Roman][SIZE=1][FONT=HelveticaNeue-Roman][SIZE=1]Slide the cartridge cap onto the new cartridge. [/LEFT]
[/SIZE][/FONT][/SIZE][/FONT][I][FONT=HelveticaNeue-Italic][SIZE=1][FONT=HelveticaNeue-Italic][SIZE=1][FONT=HelveticaNeue-Bold][SIZE=1][FONT=HelveticaNeue-Bold][SIZE=1][LEFT]5. [/SIZE][/FONT][/SIZE][/FONT][FONT=HelveticaNeue-Roman][SIZE=1][FONT=HelveticaNeue-Roman][SIZE=1]With cartridge cap in the vertical position, push the new filter
cartridge into the base grille until it stops. Rotate the cartridge
cap clockwise to a horizontal position. Flush the water
system filter.
[/LEFT]
[FONT=HelveticaNeue-Bold][SIZE=2][FONT=HelveticaNeue-Bold][SIZE=2][LEFT]Flushing the Water System After Replacing Filter[/LEFT]
[/SIZE][/FONT][/SIZE][/FONT][FONT=HelveticaNeue-Roman][SIZE=1][FONT=HelveticaNeue-Roman][SIZE=1][LEFT]Use a sturdy container to depress the water dispenser bar until
the water begins to flow. Flush the water system by dispensing
and discarding 2 to 3 gal. (8 to 12 L) of water. Cleaning the
system will take approximately 6 to 7 minutes and will help clear
air from the line. Additional flushing may be required in some
households.[/LEFT]
[/SIZE][/FONT][/SIZE][/FONT][FONT=HelveticaNeue-Bold][SIZE=1][FONT=HelveticaNeue-Bold][SIZE=1][LEFT]NOTE: [/SIZE][/FONT][/SIZE][/FONT][FONT=HelveticaNeue-Roman][SIZE=1][FONT=HelveticaNeue-Roman][SIZE=1]As air is cleared from the system, water may spurt out of
the dispenser.
[/LEFT]
[/SIZE][/FONT][/SIZE][/FONT][FONT=HelveticaNeue-Bold][SIZE=2][FONT=HelveticaNeue-Bold][SIZE=2]
[/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][FONT=HelveticaNeue-Roman][SIZE=1][FONT=HelveticaNeue-Roman][SIZE=1][/SIZE][/FONT][/SIZE][/FONT][/I][/SIZE][/FONT][/SIZE][/FONT][FONT=HelveticaNeue-Roman][SIZE=1][FONT=HelveticaNeue-Roman][SIZE=1][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT]
I have done everything, yet once I introduce the filter all the way in, and try to turn it clockwise, this will no turn AT ALL, so what’s wrong? It does it fine on the old, damage, housing.
Carlos,
Is this the filter you orderred,
You are removing the red cap off the end of the filter,
If the filter fits, but won’t twist and lock in place, you may want to put a very, very thin coat of “vaseline” or cooking oil on the spout and “O” rings, to ease the install and twist.
You may also need the check the inside diameter of the new filter housing for “slag” or an obstruction.
I bought a replacement filter housing part. I took off the plastic kick plate. I removed the 2 screws but the old filter housing will not fit through the opening to the front. I then removed the metal plate at the bottom of the back side of the refrigerator. The old filter housing can’t come out there either…it just won’t fit coming out the front or the back. Any advise is appreciated.
Scott
Scott,
You didn’t supply a model number for your fridge. Most Whirlpool refrigerators use the same filter system, and you’ve approached the repair pretty much the way it should have been. We are sending you some basic information so you can recheck or double check your procedure.
Good Luck and Thanks,
[ATTACH]4566[/ATTACH]
Binder1.pdf (169.3 KB)
[quote=Joe / APP Team;741412]Scott,
[ATTACH]4566[/ATTACH][/quote]
Thanks for your prompt reply. My Refrigerator is a Whirlpool GC5SHEXNB03. If you have specific instructions on how to replace the water filter housing for that model, I’d be very appreciative. Thanks.
Scott
Scott,
Sorry, but the basic service manual for the model number you supplied, does not have specific filter housing removal or replacement information.
Other than having the proper part number
and following the information you recieved in the previous post, and the work you’ve already performed, ( you may need to “tap” the backside of the filter, to move it towards the front of the fridge ), you should be fine.
Thanks Again,
[quote=Joe / APP Team;741430]Scott,
Thanks Again,[/quote]
Thanks again for prompt reply. It just comes down to the opening the filter housing must fit through to pull it from the front is smaller than the front side of the filter housing. I’ve tried to rotate it, move it, etc. and it simply won’t fit. I might try to call Whirlpool to see what they say. I have the part, I have the tools and it seems so simple but just can’t get it done.
Scott
[quote=dadofmo;741431]Thanks again for prompt reply. It just comes down to the opening the filter housing must fit through to pull it from the front is smaller than the front side of the filter housing. I’ve tried to rotate it, move it, etc. and it simply won’t fit. I might try to call Whirlpool to see what they say. I have the part, I have the tools and it seems so simple but just can’t get it done.
Scott[/quote]
Scott,
You’re correct, once you remove the water lines from the connectors on the back side of the filter housing, remove the two screws in the front frame, you can usually just pull the assembly out the front, you may need to twist and turn it, to extract it, but usually nothing major.
We wish we had more information, but that’s all we have. Let us know what you needed to do, That way everyone reviewing the Repair Forum can refer to it, if they have a similar issue.
Thanks Again,
