Replace thermostat(s)
:confused: I just replaced the heating element, which was totally fried. However, no heat. Should the thermostat also be replaced? Or, to be safe since the dryer is fairly old, should I replace both thermostats? Is there a way to test the thermostats?
Replacement parts for Whirlpool LER5644JT2 RESIDENTIAL DRYER | AppliancePartsPros.com
See the attachment for the wiring diagram.
Thermostat’s can be checked with a meter. They should be 0 ohms at room temperature.
Just guessing at what is blown can cost a lot of dollars.
I would check the power first and then the thermostats.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts. This is the heater power.
If OK
If OK
Do this with the heater off and on.
[COLOR=“Red”]Be careful as 240 volts is lethal !!![/COLOR]
NOTE: There is a safer way to check for 240 volts on this unit as the timer motor uses 240 volts. So if you put the unit in timed dry mode, mid cycle and start it and the timer advances you know that you have the 240 volts.
  4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
LER5644.pdf (251.5 KB)
