I need help replacing door mullion part #20000246 on thermador refrigerator
What kind of help are you needing? To replace it you would open the door and flip the mullion out. You would then remove the screw holding it in place. Then lift the mullion off and disconnect the wire.
I saw a video do you need to remove the door bins ? Is there one screw? I see torque screw upper and lower - I broke the mullion hinges
Door bins should not need to be removed and there should be screws holding it in place.
ok ty for your help with this
