Replace Samsung ice maker auger motor
Brand: Samsung
Model Number:RS261MDBP/XAA
Main Symptom: auger motor replacement
Parts or tests already tried: part number DA31-00105G auger motor on hand - need replacement instructions
To access the motor, remove the ice bin. There will be screws on the side that under the shelf that holds the bin that you will remove to slide the assembly out. Once out you will then there will be a couple of screws that hold the motor in place but you will need to remove the coupler on it first.
Is there an electrical connector to this assembly? How do I access this electrical connector?
When you slide the assembly out there will be a connector at the back that will be able to be disconnected.
