I have a Jenn-Air refrigerator with incandescent whirlpool bulbs PN 2326255 (40 Watt) and want to replace with LED bulbs (should be 5 Watt) to you have a recommended bulb PN? The current bulbs get too hot, its a refrigerator not an oven. Can you help?
I am not a parts person so do not have a part number for you.
I would take the bulb to Home Depot etc. to find a suitable replacement.
Check in the unit where the bulb goes so you know how much room you have as it is unlikely that you will find one that is the exact dimensions of the old bulb.
The base of you bulb looks like it is an E12 candelabra but I am not 100% sure about this. You have to make sure they match as there are also E14 bulbs out there and the sizes are close.
