model # kebc208kss0- double oven. I need to replace door latch assembly on bottom oven,how do I seperate the two,(black screws on the side bracket or is there more).
[quote=Ramm;315672]model # kebc208kss0- double oven. I need to replace door latch assembly on bottom oven,how do I seperate the two,(black screws on the side bracket or is there more).[/quote]
[COLOR=βRedβ][SIZE=β4β]DUPLICATE[/SIZE][/COLOR]
Please see the following
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/151715-double-oven-door-latch-kitchenaid.html
