Need instructions to remove microwave oven to access burnt-out bulb. Have already bought new bulb.
The instructions are attached to the post.
Just to verify if the light bulb you have is the correct part, the following is the AP6021432
Here are the breakdown diagrams and Parts for Whirlpool KEMS378GSS0 Wall Oven - AppliancePartsPros.com
Removing the microwave.pdf (546.0 KB)
Removing the convection temperature sensor - the halogen lamp - the cavity thermal fuse.pdf (461.5 KB)
Thanks Gene. I believe part number (bulb for microwave over) is 4452164, which I have ordered.
Spelman
Spelman,
The part number I posted, came up by the model number you provided. The part number 4452164 does not cross to W10440740, so I’m not sure if it will fit and work properly.
P.S. I found the light bulb with the part number 4452164. It’s shown as the oven light bulb (#12 at the diagram). I’m afraid they might be not interchangeable.
