Hi, We finally replace the water filter after a couple weeks of the water not working. When we push the water dispenser on the front of the refrigerator, we get only a few drops and then it stops. I am concerned that the water line may be clogged. We tried to use the repair tips, but not sure exactly what we are looking for on this model. Please help!!
Did you check and make sure you put the right filter in some aftermarket filters do not work on certain units? Also did you pull off the cap if your filter came with a cap before installing it? Is the filter screwed in all the way properly? Check your water line coming into the fridge and make sure you even have water coming to your fridge.
