My door handle is broken. I have a replacement..but do not know how to do that. I removed two door handle screws but that did not release the old handle.
J,
Here’s what little information we have, I think you’ll be able to repair the handle with this little bit of information,
[FONT=Arial-BoldMT][SIZE=4][FONT=Arial-BoldMT][SIZE=4][LEFT]LOOSEN THE DOOR TRIM[/LEFT]
[/SIZE][/FONT][/SIZE][/FONT][FONT=ArialMT][LEFT]1. Place a towel or a soft cloth on top of the dryer or work space to protect the door surface.
2. Loosen the plastic trim (1) above and below the handle filler (2).
3. Carefully pull out on the trim until it unsnaps and remove the handle filler and set it aside. [FONT=ArialMT]Carefully pull out on the trim until it unsnaps.[/FONT][/LEFT]
[FONT=ArialMT][FONT=ArialMT][LEFT]Remove the two screws from the door handle and remove the handle by pulling straight out on it.[/LEFT]
[FONT=ArialMT][LEFT]Insert the new handle into the side opening of the door. Make sure that the handle seats all the way in the opening, and that the holes are all aligned properly, then mount the handle with two screws.
Hope this helps,
[/LEFT]
[/FONT][/FONT][/FONT][/FONT]
