replace door switch
how do i open machine to relace door switch? it has plastic end caps on the control panel
Look at the back of the end caps, you will see screws on each side to remove, then pull panel forward, then tilt back. Remove both ripply retainer clips and lid switch connector, then tilt panel away from washer.
