Replace door balance kit rope
Hi there…I replaced the two ropes that engage the dishwasher door springs, everything is good except now the door pulls just a bit to the right,the center latch where the door locks top center is off just a bit when you close it. When you push it and shut it, it squares up , closes and locks but I’m concerned about this " pulling to the right "…any ideas, put both on identically, make some sort of adjustment ?
thx
Paul
Yes I would check if the springs do have different settings.
Also check that the door hinges are OK
