Replace broken heating element
The lower heating element broke while it was self cleaning. I have the part to replace it, but no instructions on how to do it. Can you please help?
Unplug the range. Remove the screws that hold the element to the rear wall of the oven. Carefully pull the element out and remove the wires connected to it. Installation is reverse.
Thank you so much!!!
