My refrigerator (GE Model TBX19JASNRAD) has started to have a build up of water right under the vegetable and fruit bins. Is there something that I need to do or correct this? A couple of friends say that the refrigerator is about to stop working? Is there anything I can do to save my refrigerator?
Thank you very much!!
RJennings
jenningsr8@hotmail.com
Your drain tube must be stopped up with ice at the upper end because it drains too slow because it’s stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little air pressure will usually clear it out. Flush it out with hot water and clorox may help. Make sure it drains quick enough. The drain should be located below the evaporator coils on the lower back of the freezer.
