I have a a PLEB27M9EC oven / microwave combination. My microwave is not working, the timer counts down and the light comes on but no heating or spinning. I figured out if I press on the door open button slightly, it will begin heating. I assume this means the door sensor switch needs replaced but I cannot figure out how to get the panel off. I’ve uploaded some pictures:
Imgur: The most awesome images on the Internet
I’ve removed the stainless steel think piece that wraps the control panel. I see no screws that are securing the panel from sliding up and being removed. When I pry on the right side I see The clips and it definitely looks like it must slide up to come out. I cannot slide it up because the black metal lip on the top of the unit is blocking it.
Does anyone have any experience on removing this panel?
Can anyone help?
