[SIZE=2][FONT=Times New Roman][SIZE=3]I just received my Electronic Clock Unit today that I ordered from the Appliance Parts Pros. I’ve removed the lower screws on the panel, but I can’t figure out how to get the cook top up. I’ve read on several posts here about retaining clips and screwdrivers, but I haven’t been able to locate them. Any help would be greatly appreciated
Maytag CHE9800BCE
Thank you,
Chryslerpetz.
[/SIZE]
[/FONT][/SIZE]
Hi, [FONT=Times New Roman][SIZE=3]Chryslerpetz [/SIZE][/FONT]
[FONT=Times New Roman][SIZE=3][/SIZE][/FONT]
[FONT=Times New Roman][SIZE=3]Using a putty knife, push the locking clip (#11 on the top assembly break down diagram) on each side under the top panel and lift the top panel.[/SIZE][/FONT]
[FONT=Times New Roman][SIZE=3]Remove all screws held the control panel and pull it toward yourself .[/SIZE][/FONT]
[FONT=Times New Roman][SIZE=3] - Here are the break down diagrams for the Maytag range Model CHE9800BCE[/SIZE][/FONT]
[FONT=Times New Roman][SIZE=3]Good luck.[/SIZE][/FONT]
[FONT=Times New Roman][SIZE=3]Gene.[/SIZE][/FONT]
Gene you’re a Gentleman and a Scholar! Your tip is just what I needed. Armed with your instructions the timer was installed in 15 minutes. I can’t thank you enough. At our next oven cooked meal we will toast to your long life and good health.
Chryslerpetz
Happy New Year!
