I have a GD25DFXFB02 Whirlpool Side By Side Refirgerator. Initially I did not have water or ice to the door. I replaced the water inlet valve which solved the no ice issue. I now have PLENTY of ice and my wife loves me again. However, in order to regain the full graces of my wife, I need to also have the water issue completed.
From what I understand (maybe incorrectly) if the water valve has been replaced and I still have no water in the door, it is most likely the micro switch in the door dispensor itself. When I depress the lever nothing (no sounds at all) happens; which to me would indicate the water valve is not getting the message the door is calling for water…so I ordered a new micro switch and need to know how to get the dispensor apart to replace the switch. it is not readily apparent to me how to dis-assemble it without damaging it. If someone could please post a link or instructions on how it all comes apart, I think I can take it from there.
Thanks!
