Removing Icemaker
How Do I Remove The Icemaker From A French Door Refrig. With Ice Maker In Top Left Corner Of Refrig. (after I Have Removed The Ice Bin With Auger)??
there are two screws at the top of the ice maker in the upper left there is also one screw at the bottom lower left … Remove screws and disconect wire plug and the ice maker will be relesed from the refer
Gene:
Thanks For Replying. This Is A Maytag, But Apparrently Icemaker Is Made By Whirlpool. It Appears To Be On A Track Against Left Wall Of Refrig And There Is A Tab At Front Of Track Which Can Be Lifted To Release Icemaker, But There Is Something Else Holding It, Because It Doesn’t Bodge. Is There A Screw Somewhere Along The Bottom? I Can See A Hole In Bootom At The Rear Of Icemaker, But I Cannot Tell If There Is A Screw In Hole, Because It Is Recessed About An Inch And I Cannot Get My Finger In It. Cragin
Oh its that type of ice maker … Im sorry for the confussion and yes there is a screw on the bottom of the ice maker that will need to be removed before it will pull out … A 1/4 inch nut driver will remove it.
