Removing Agitator
I have oil leaking into the wash tub and believe I need to replace seals (my washer is 17 years old). The problem is I cannot see a top cap or any
way to remove the agitator. How is this done on my unit? Thanks.
Remove the dispenser (#1 on the agitator break down diagram), remove the screw (#6 on the agitator break down diagram) and lift the agitator.
Here are the break down diagrams for the Speed Queen washer Model NA4521
On my Speed Queen Mod. No. NA 4521, there is no dispenser. There doesn’t seem to be a way to get to the bolt #6 through the agitator #7? Help!
Did you try to pull the agitator up? It could be very hard.
Put a rope under the agitator, and pry it off with a 2x4 and the top as a lever.
