Remove Oven Temperature Sensor
Brand: Whirlpool
**Model Number:**RBS305PDQ6
Main Symptom: E3 -F2-
What happens & when: Started beeping. Oven was not in use. Worked yesterday. This is a built in oven. Do I have to remove the oven to remove the sensor?
Error Code (if any): E3 -F2-
Parts or tests already tried: Turned off oven at breaker for a while then on still beeps.
Bogward1,
Thank you for your question. The sensor should be able to be removed from inside the oven. There will be 2 screws holding it in place. Keep in mind that when you pull the sensor out, use a clip or something to keep the wire from sliding back into the wall. If it does and you are unable to get it out then the oven would need to be pulled out at that point.
