Am trying to change bearing for noisy dryer. I have removed all rear and underside screws but still cannot remove back panel. what am I missing??
You need to put it all back together before you totally mess it up. You need to do it from the front, not the back. Remove the top panel, remove the front panel, remove the drum, then you can change the bearing.
