I need to replace the heating element but I don’t know how to remove the cabinet. The filter is on the front.
[FONT=Times New Roman][SIZE=3][COLOR=#000000]You remove the bottom front panel (under the door) by pressing in on two clips in-between the panel and the door. Once off you should see the element on the right under the drum. Hope this helps! Clothes Dryer Repair Guide[/COLOR][/SIZE][/FONT]
The clips that he is talking about, are at the top of the bottom panel, about 4 inches from each end. It is best to slide a putty knife in there, and it will release the front real easy. Tom ApplianceEducator.com
