I need to replace the inlet valve or mixer valve on the back of the washer because it is leaking. I know the part no. is AP3094541. I do not know how to remove the back panel of the washer to replace the part.
The rear panel is not removable. You have to remove the washer cabinet to access the water valve. The instructions are attached.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL TAWB600EQ1 | AppliancePartsPros.com
How to remove the washer cabinet.pdf (43.5 KB)
