Hello,
Please help. I need to remove the top of the dryer to change the belt, but can’t get the pins to release in the front. Thanks in advance.
Hello,
Here is the instructions from the service manual.
[FONT=Arial][LEFT]Cabinet Top[/LEFT]
[/FONT][FONT=Arial][SIZE=2][FONT=Arial][SIZE=2][LEFT]1. Disconnect power supply to unit.
2. Remove control hood assembly,
3. Remove front panel,
4. Remove screws securing cabinet top to side panels.
5. Raise cabinet top to a vertical position.
6. Carefully disconnect wire harness and feed harness
through cabinet top access hole.[/LEFT]
[/SIZE][/FONT][/SIZE][/FONT][FONT=Arial][SIZE=2][FONT=Arial][SIZE=2][LEFT]NOTE: [/SIZE][/FONT][/SIZE][/FONT][FONT=Arial][SIZE=2][FONT=Arial][SIZE=2]Cabinet top may be raised and hinged on the
rear hold-down hinges or supported against wall
while servicing dryer.[/LEFT]
