refrigertor freezer
hello everyone,I have frigidaire refrigeraton side by side,i replace the defost timer and therostat but ice still bulding up on the back panal and coil,stopping the freezer frigeraton from getting cold.so i turn it off for a day,it start back working it will last for two or three day.can someone please help me out.like i said i buy defost timer and thermostat.email markcorneliussr@yahoo.com:confused:
i still have the refrigeraton,can not buy a new one please help me out.
A Model Number may help others help you.
Did you check the heater for continuity with a meter?
Also it is always possible that one of the parts you replaced was defective.
Try the following:
First remove the evaporator cover in the freezer so you can see the coils.
Not do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If yes.
Manually force a defrost cycle by turning the defrost timer cam till the fans and compressor turn off.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing, re: it is probably stalling during it’s rotation so is never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost timer contacts are toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
