Refrigerators
This is a side by side unit. The area between the freezer & refrigerator, where the doors contact, is so hot that it will burn you. I am supprized that it has not melted the rubber on the magnetic strip. It is not warm anywhere else & is still making Ice. Is there a heater strip here? I thought that the defrost timer had went bad so I turned it. It has not made a differance. What can it be?
Replacement parts for WHIRLPOOL RS25AGXNQ00 Refrigerator | AppliancePartsPros.com
The most common cause is dirty condenser coils or the condenser/compressor fan is not operating correctly, see section 10.
[quote=denman;226914]Here are your parts
The most common cause is dirty condenser coils or the condenser/compressor fan is not operating correctly, see section 10.[/quote]
Thank You, I clean them and see what happens
Dale
Thank You for the help,
The coils were very dirty. looked solid, I blew and vacumed them and I think this has fixed the problem.
