i have a late model caloric refrigerator and was wondering where the drain line is? i have a problem with to much water standing in my crisper drawer and under it also and also on all my items inside the refrigerator so i am assuming that the drain is stopped up and i can’t seem to figure out where the drain is located it is frost free any help would be greatly appreciated.
You will find it behind the freezer panel and under the evaporator. Use a turkey baster and hot water to thaw out the drain. You can use a 10 gauge copper wire to wrap around the defrost heater, then push it down the drain, it will prevent future drain problems.
