Brand: Samsung
Model Number: Rh22h9010sr
Main Symptom: Water dispenser suddenly stopped working midstream as I was getting water.
What happens & when: No water come out and makes a hammer noise. Dispenser does work without filter but stops when filter is inserted
Hello, I would replace the filter, it sounds like it is stopped up being that it runs without it. https://www.appliancepartspros.com/samsung-water-filter-da29-00020b-ap5271937.html
I have tried two brand new filters, and it still doesn’t dispense
In that case, the bypass in the filter head is not opening and closing properly. the problem has to be in the filter housing.DA97-14655C Refrigerator Water Filter Case Assembly | Genuine Samsung OEM In Stock
Good advice on the filter holder. Worked on mine. Issue sounds exactly the same. Seems impossible but a new holder worked and it was an easy install.
Glad it worked out for you.
