The water dispenser barely dispenses water. When I install the by-pass plug everything flows good. I have purchased 2 filters and neither one works. I have inspected for any kinked lines and I made sure I had proper water flow to the filter. I have checked the dual water valve and everything checks out. Again, when I install the by-pass plug the dispenser works great but when I re-install the brand new filters it doesn’t work. I have flowed a good 4 gals of water through it in case there was an air lock.
Any suggestions?
