Refrigerator section freezes everything
This unit is one with french doors and bottom freezeer with ice-maker in the refrig. section. Everything in the refrig. section is freezing. There is no tech. sheet to be found to run a diagnostic test. Can you help?
Here are your parts.
You will have to choose a unit in the Matching Model Numbers section.
Parts for MFI2266AES - AppliancePartsPros.com
Run the diagnostics to see if the damper opens/closes.
MFI2266.pdf (285.6 KB)
