Refrigerator Repairs
I Have A Question About May Frig.maytag Model msd2957aew.the Frig Part Will Not Cool Down And The Freezer Part Is Sub Part Performance.also Water Accumulates On Bottom Of Freezer Like A Glasier All The Time.what Should I Check First.i Am A Good Technician And Just Need Some Guideance
In The Right Direction.any Known Common Concerns With This Brand And Model? @ Evaporator/heater System?.any Help Would Be Apprieciated.thanks-t/o.:slight_smile:
Thanks For All The Help And Info-.i Put Th Adc Module In And Totally Defrosted The Glasier Around The Evaporator Assembly,cleaned Out The Frosen Drian Tube-tested Thr Defrost Heater And Thermostat-good.fired It Up And It Hasnt Worked That Good Sense I Bought It,also Note!!! The Auto Ice Maker Started Working Again,possibly Related To A Sub-par Temp In The Freezer Compartment.!!! Thanks Again.!!!
