Refrigerator not running after power outage
Brand: amana/whirlpool
Model Number: ASI 2575FRS00
Main Symptom: refrigerator cools/freezes to optimum temperature then stops running.
What happens & when:After awhile and temperature is warm, re-pluging it in will activate it again sometimes. Have replaced starter relay and compressor capacitor. Compressor tested to be fine.
Barglefarkle, it sounds like the defrost control board may have an issue. An easy check would be unplugging the power cord and testing the temperature control thermostat for continuity with a multimeter. If it has continuity, the defrost control is the most likely cause of failure. WPW10366605 Refrigerator Defrost Control Board | Genuine Whirlpool OEM In Stock
