Refrigerator not maintaining temperature
Brand:Frigidaire
Model Number:FFHS2611PFEA
Main Symptom:refrigerator not maintaining temp. Goes from 32F to 54F
What happens & when:Completely variable. When warm, door does not seem to be allowing cold air from freezer.
Error Code (if any):H1 of course
Check to see if there is air coming from the vent in the top back of the unit. If there is not then open the freezer door to see if air flow improves. If it does then check for blockage of the return vent behind the crisper drawer that goes into the freezer section. If the airflow does not pick up then it sounds likely that the damper may be faulty.
Yes, you got it correct. That’s exactly what it was. Thanks. I ran the diagnostic per the .pdf I was sent from Sally and it showed number 4 (motor failure). The problem was leading up is it was intermittent and hard to diagnose, until it completely failed. It now holds 34 degrees.
Thank you again
-Chris
