I have a GE side-by-side refrigerator. Twice in the last 2 months we have had the following happen.
on the fridge side the light assembly at the top gets extremely hot - too hot to touch and the lights go out.
the freezer/fridge cool adjustment controls go dark.
the fridge gets warm as it is no longer cooling.
after unplugging the fridge for 30 mins or so and then plugging back in, it seems to “fix itself” with the cooler controls lighting back up and the light assembly no longer warm, and the fridge works normally again. Please help!!!
The light goes off when the door shuts, so that’s not it. I think the problem may be with with the power supply in the light assembly - but I am only guessing. I tried to call GE but didn’t get anywhere since they have no technical help line…anyone have any other ideas?
Exact same issues. Light assembly was off but extremely hot to the touch. Temp in the fridge rose to 60 degrees. Power cycled the fridge and light came back on and is cooling down. I believe the light assembly got so hot the lights shut off and the temps in the fridge started to rise. Any ideas? Is it the main board or the light assembly? Thanks!
Please, does anyone have any ideas? Main board or light assembly? What would cause the light to come on while the door is closed? Switch is functioning and is located inside the door area so sagging door is not possible. Please help
open the door and push the light button. does the light go out? try this several times. if the light goes out each time then the switch is good. when you find the light stuck on, does the light go out when you push the switch? if not, you have an intermitent switch. the current flows from the board to the switch, when you open the door the contacts inside the switch close and sends one side of the current to the lights. the other side of current is already there. unlikely the board. it is possible that there is a short and the lights are picking up current eslewhere, very unlikely. there is no transformer on the lights. works just like a lamp. check these things. if still a problem let me know. i have access to g.e. tech assist.
thank you for the response and effort. Yes the switch seems to be working properly. I’ve pressed it maybe 2 dozen times and I’ve yet to see it not turn the light off. When I found the fridge in the overheated state, the lights were off (maybe a temp cutoff) but extremely hot to the touch. Removed the plastic cover and the entire housing (metal) was hot hot hot. After unplugging and plugging back in the light came back on and worked as normal.
As for now I’ve removed the bulbs and no issues since. Good to know it’s just a a switch and board with nothing in between. I have no issues changing the board but I hear from other boards it does not resolve the issue. I’d hate to change boards over and over again only for it to happen randomly again.
talked to g.e. tag team. they think the plasic that the switch plugs into is contracting and causing the switch to move away from the door enough to close the contacts. they have a part no. to repair. part no. wr2x8905. order two. these are self adhesive strips that attach to the actuator of the switch. they advise putting two strips on. they also say put a little glue on switch actuator to be sure the strips stay in place. wr2x8905 is the original g.e. part no. hope this solves the problem.
Scott you the man. I really appreciate it. Ill update my findings but it happened so randomly I don’t know if or when it’ll happen again. Rally really appreciate this
[QUOTE=scott5495;815535]i will contact g.e. technical assistance on your behalf monday. they may already know about the problem. i did not find a service bulletin on it.[/QUOTE]
Did you ever get any help from tech support? I’m have the exact same issues. Unplugged it and problem went away for about 48 hrs.
ge thinks the plastic mullion that the switch is in is conracting and causing the switch to move away from the door and causing the contacts in the switch to close and turn the lite on. they recommend part no. wr2x8905. order 2. these are adhesive strips that attach to the switch plunger. they recommend adding a little super glue to the plunger to help secure. hope this helps.
[QUOTE=scott5495;816337]they recommend part no. wr2x8905. order 2. these are adhesive strips that attach to the switch plunger.[/QUOTE]
Hi Scott,
I’m also experiencing the same light-assembly-running-hot issue in my GE Profile side-by-side fridge. I’ve pulled the bulbs from my fridge in the meantime, but I’d like to try fixing the issue.
When I search for GE part number WR2X8905 all I can find is a “vacuum break” which does not appear to have anything to do with adhesive strips.
If possible, can you link directly to the adhesive strips you mentioned?
scott5495 has not been on his site for several months so i will try and help.
Looks like the problem he is referring to is that the door switch does not close all the time so the light stays on when the door is closed.
I do not know the GE part that he is referring to.
You could try calling GE.
If you can figure out what thickness has to be added to the switch activator then you should be able to use something else.
The little felt buttons they use to keep cabinet doors from being noisy when they close or the self stick pads they use on the bottom of chair legs etc. may work.
If the light is going off when the door is closed then you have a different problem.
Perhaps you could get a LED bulb that you could use. They do not give off heat.
You would need one that is like a Xmas tree (a stalk with LED’s around it).
Many of them just have LED’s at the end but I think these would be too directional in a fridge. Would give light like a spot light.
In the last couple of weeks my GE side by side has had this problem. The refrig side is warm. I notice the top light is off and warm but the lower light is on. I adjust the temp, turn on turbo cool. Check again and the light is on and seems to be cooling. The light switch seems fine as it operates both lights. Any ideas?
Thanks.
I’m not sure I fully understand what’s going on. What exactly is happening with the upper light? Is it on when you open the door, and does it only operate when you press the light switch? I will be glad to help just need a few more details.
The refrigerator side warms up. The top light was off and warm around the fixture housing. The lower light was on. Which would eliminate the the switch being bad. I thought the top bulb might have been bad. I had the temp set to 37 but showed to be 40. I adjusted the temp down. When checking to see if it was cooling, the top bulb was working again area around it had cooled off. The freezer side seems to be fine. I was wondering if a sensor could be bad.
