Our unit has started leaving puddles on the floor. Not all the time - but when it does, there is enough water it must be cleaned up, a true puddle.
The ice maker is not connected so it cannot be that.
Sorry, I did not mean to stump everybody. Still have the problem … I’ll keep looking
If it is a side by side, check to see if there is a sheet of ice in bottom of freezer. If so, defrost drain is stopped up.
