What happens & when: fridge will get cold until defrost cycle and then it will not kick back on. We have replaced the thermostat, the heating coils, and the main control panel. when we plug the fridge in, it kicks on and gets cold. Once the defrost setting kicks on, it will not get cold again. The fan motor works fine so it’s not that. I think it might be the refrigerator/Freezer Compressor Start Relay so I ordered that part but is there a chance that it is not and is some other issue?
Error Code (if any): N/A
Parts or tests already tried: thermostat, the heating coils, and the main control panel
Yes, the compressor start device/relay could cause a no-start, and the correct start device listed for your WRB322DMBW00 is WPW10448874. Whirlpool Parts
However, because the refrigerator starts and cools normally every time you unplug it and plug it back in, but fails specifically after a defrost cycle, I wouldn’t assume the start relay is the problem yet. That pattern makes me want to determine whether the compressor is actually being told to restart.
The quickest check is to wait until it has gone through defrost and fails to start cooling again. Don’t unplug it. Go to the compressor and listen/feel what it is doing:
Repeated click every few minutes, compressor tries to start but can’t: the start device/overload is a strong possibility. Replacing WPW10448874 makes sense. A failing compressor itself can produce the same symptom.
Compressor is completely silent and not trying to start: I’d be looking back toward the control/temperature-sensing circuit or wiring, rather than the start relay.
Compressor is running but it isn’t getting cold: then we’re dealing with a different problem, potentially the sealed refrigeration system.
Since you’ve already replaced the defrost heater, thermostat, and electronic control, I especially wouldn’t keep replacing parts without doing that check. The model does use an electronic control, WPW10503278, and the start device is WPW10448874
I did the listening test and did hear a very light clicking sound every 15 seconds or so and the compressor did sound like it was on. I took off the relay and it did have a little noise to it when I shook it but will compare when the new relay comes in today.
